donawalt
Aug 16, 2022Mentor - Experienced User
what do Internet Connected and Time Sync msgs in pairs mean?
I have an RBR850 and 2 RBS850s with wired backhaul. This weekend I noticed my router time was off an hour -- I did not have the DST check box selected. So I did that. Today, I was looking at the log...
- Aug 16, 2022
DHCP lease renewals start trying at 1/2 the lease time (or so I've been told). So two hour lease time could renew as early as 1 hr.
For me, I get a 24 hour lease, and I'm pretty consistent at 12 hr DHCP requests from the WAN.
I've also seen on occasion when I get a different server in the pool at the ISP (Charter) that has lease time set to 1 hour or 2 hours instead of 24 hours and it hits them occasionally, then ultimate goes back to the 24 hr lease.
As long as you are not seeing disconnects, then it's just normal activity.
TC_in_Montana
Aug 16, 2022Virtuoso
That usually corresponds with a lease renewal from the ISP. Everytime the lease is renewed, the Time is synchronized as well.
You can look at your lease time by clicking on the Advanced Tab in the WebUI Admin page, then in the Internet Port box, click on COnnection Status.
It is unusual for them to change time (minute wise) - mine are pretty consistent. However, I believe you are still doing IPV6 stuff, so wondering if maybe it is getting a change in time if it loses IPV6 and reconnects via IPV4. (Just a guess here).
If it continues to be at wonky times (not a consistent hourly or 12 hour or whatever), it could actually be showing a disconnect/reconnect from the router to the modem/ISP. But I would think you would see an "Internet Disconnected" message then as well.
- donawaltAug 16, 2022Mentor - Experienced User
Thanks TC_in_Montana . To comment on your points/suggestions:
- I don't think I have lost internet connection, I added above in an edit, I was doing constant speed tests through one of the logged times, plus I have had no indication of it otherwise. RBR log only has DHCP messages otherwise, no other types of messages are showing in there.
- I think IPv6 has been fine for about 3 days this last iteration, but I guess it's possible a particular device could be having trouble with IPv6?
- My lease is apparently 2 hours. I don't see a consistent 2 hour log entry in my example above though. Maybe it's been varying for some reason? My modem logs look fine, only notice messages no errors, critical etc. Speeds fine too.
- Just for grins, I disabled IPv6 - t see if the log messages change or reduce. I am suspicious....I'll report back.
- TC_in_MontanaAug 16, 2022Virtuoso
Thanks TC_in_Montana , makes sense!
