_jude_
May 18, 2022Tutor
What is the status of this issue now?
What is the status of this issue now? The last update was on Monday, can you please at least provide a daily update for this issue? Thanks.
May 18, 2022Guru - Experienced User
All you can do is keep checking this:
If your having problems, you'll need to contact NG support.
https://my.netgear.com/support/contact.aspx
Last resort for more immediate access to the RBR is to factory reset and setup from scratch using a wired PC and web browser.
