sh2sg
Jan 19, 2022Apprentice
What is the surface material used for RBKE 96x?
I am thinking of getting latest Orbi WiFI 6E set RBKE963 or RBKE963B, but I worry about its surface material, if it is same as my current RBK53, it became very sticky and dirty only after 2 years, an...
- Jan 19, 2022
sh2sg wrote:I am thinking of getting latest Orbi WiFI 6E set RBKE963 or RBKE963B, but I worry about its surface material, if it is same as my current RBK53, it became very sticky and dirty only after 2 years, and worse over the time..
I've owned the AC, AX, and AXE Orbi models and can report that they changed the surface material after the RBK5x series (which had a rubber-like feel). The AX and AXE models have a regular, smooth plastic surface that doesn't get sticky like the RBR50 and RBS50 units.
Also check out the recent recommendation on how to reduce the RBR50 stickiness. I tried it and it does make it better: https://community.netgear.com/t5/Orbi/Orbi-RBR50-material-became-sticky/m-p/2184873/highlight/true#M130512
Mikey94025
Jan 19, 2022Hero
- sh2sgJan 19, 2022Apprentice
Thanks for the quick reply, and confirmation!
