UARK
Sep 13, 2020Aspirant
What recommended cable modem for AX4200
I am wondering which cable modem that you all recommended for AX4200 mesh wifi system (cbale provider is COX). Welcome and appriacate for any suggestions. Thanks Note: looking for DOCSIS3.1 with ...
Sep 14, 2020Guru - Experienced User
Netgear makes several devices that are Docsis 3.1 capable.
CM1000
CM1100
CM1200
CM2000
It all comes down to what you want. I wouldn't recommend the cm1200 just because it has 4x ethernet ports (cost extra for) and for most users, they can't use them. Reason why is that unless you have business class line or pay for multiple public ip address, you can only connect 1 device to the modem. Meaning the other ethernet ports are pointless. Both the cm1100 and cm1200 support port aggregation so ports 1 & 2 are useful if you're using that. but again, if you don't pay for the extra or have business class, ports 3/4 dont' do you any good.
UARK
Sep 14, 2020Aspirant
Thanks for the recomenedation.
I was thinking netgear CAX80, but it is unbelievable expensive. So, I think CM1100 is a good alterative choice.
By the way, CM2000 has not coming out yet, right? The official website said this product will be available around 9/24. So, I guess this is a new product, right?
- plemansSep 14, 2020Guru - Experienced User
The CAX80 is a modem/router combo device.
the CM2000 has been released, it just sold out quickly. The CM2000 has a 2.5G ethernet port on it instead of using link aggregation like the cm1100 and cm1200.
- MstrbigSep 14, 2020Master
Arris SB8200 would be the fastest as it is DOCSIS 3.1 and has great specs.
Arris SB6190 would be a second choice. It is DOCSIS 3.0 and pretty much has the same specs as the SB8200.
So if you want to go with Netgear, choose one that fits those specs.
- FURRYe38Sep 15, 2020Guru - Experienced User
NGs CM1000 thru 2000 are all D 3.1 modems. CAX80 is as well.
I would avoid the Arris 6190:
