UARK
Sep 13, 2020Aspirant
What recommended cable modem for AX4200
I am wondering which cable modem that you all recommended for AX4200 mesh wifi system (cbale provider is COX). Welcome and appriacate for any suggestions. Thanks Note: looking for DOCSIS3.1 with ...
UARK
Sep 14, 2020Aspirant
Thanks for the recomenedation.
I was thinking netgear CAX80, but it is unbelievable expensive. So, I think CM1100 is a good alterative choice.
By the way, CM2000 has not coming out yet, right? The official website said this product will be available around 9/24. So, I guess this is a new product, right?
Sep 14, 2020Guru - Experienced User
The CAX80 is a modem/router combo device.
the CM2000 has been released, it just sold out quickly. The CM2000 has a 2.5G ethernet port on it instead of using link aggregation like the cm1100 and cm1200.
- MstrbigSep 14, 2020Master
Arris SB8200 would be the fastest as it is DOCSIS 3.1 and has great specs.
Arris SB6190 would be a second choice. It is DOCSIS 3.0 and pretty much has the same specs as the SB8200.
So if you want to go with Netgear, choose one that fits those specs.
- FURRYe38Sep 14, 2020Guru - Experienced User
NGs CM1000 thru 2000 are all D 3.1 modems. CAX80 is as well.
I would avoid the Arris 6190:
