Jeffgear
Nov 14, 2025Virtuoso
What should I believe is the actual connection speed?
I've got 2 860 sats that show as connected at 5Ghz and "good" in the attached devices table but the connection status stats shows the WLAN backhaul running at 2402M. What should I believe is the actu...
Nov 14, 2025Guru - Experienced User
Tech specs are this for this series of Orbi:
Orbi AX6000 Router and AX6000 Satellite
(2400 + 2400 + 1200Mbps)†
2400 would be the max rated connection rate between the RBR and RBS for BH in a perfect setting. Building materials and distance will impact that and since we don't have low level access to FW output via telnet anymore, can't read what is actual.
