LauraAMayer
Oct 22, 2020Aspirant
What should I get?
Which one should I get? My computers are so slow. I don't know whether to get the RBK44 System or the AX6000. Right now all I have is a ViaSat modem/router, and I am worried about security and gettin...
Oct 23, 2020Guru - Experienced User
Ether one.
The Orbi AX is for AX supporting devices. If you don't have any then either get the RBK44 system or you can future proof with Orbi AX. Also there maybe a cost difference.
If you have a modem router already, and add a Orbi system, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Good Luck.
