RockTheGlobe
Jul 23, 2024Apprentice
What's the max speed on the RBK753?
I recently had Ting fiber installed at my house, and I'm supposed to be getting 2Gbps symmetrical speeds, but when I run a SpeedTest from within Orbilogin.net or the Orbi app, I'm only showing 1Gbps....
- Jul 23, 2024
The 750 series is only capable of 1Gb speeds UP and Down due to the max connection rates for the WAN and LAN ports. If you want 2Gb seemlessly from both WAN and LAN ports, you'll need to review Orbi 960 or 970 series.
RockTheGlobe
Thanks! I thought that might be the case but wanted to make sure.
Jul 23, 2024Guru
