fanandfoe
Jun 08, 2022Guide
Whelp, my ticket was closed without an update from Netgear support
Whelp, my ticket (#45999342) was closed without an update from Netgear support on the firmware issue. Yes, I am aware that Netgear has "a fix that we are slowly deploying to a small group of users an...
Jun 08, 2022Guru - Experienced User
I recommend that you avoid the wait and regain access to your RBRs web page by doing a factory reset and setup from scratch at HTTP and 192.168.1.1 in a web browser by pressing the reset button on the RBR for 20 seconds then release. Ethernet connect 1 wired PC to the back of the RBR.
Walk thru the set wizard.
If you still have access to the RBS web pages after they resync, I recommend that you manually update the RBS First then the RBR lastly to v.2 FW:
- fanandfoeJun 09, 2022Guide
I appreciate your suggestion and well-worn path to a usable product. The only problem is that I have a full-time job that takes 12+ hrs a day already. I don't want to spend my nights undoing what Netgear did to my router. I expect them to make this right.
