sureshsumithra
Aug 17, 2020Aspirant
When AX 6000 launched
When AX 6000 launched. Whether AX 6000 is latest version or any updated version released
- Aug 18, 2020
There is 8 and 7 series Orbi AX, 6000 being 8 series and 4200 being the 7series. They are mostly same accept the wireless connection rates supported on the web 7 series is slower than the 8 series. You can review the data sheets for each model to compare differences.
Orbi 8 series launched last year while the 7 series launched this year.
Aug 18, 2020Guru - Experienced User
ax6000 is a speed and not a model.
Are you wondering when the RBK852 will launch (it has) or what are you asking about exactly?
https://www.netgear.com/orbi/rbk852.aspx
- sureshsumithraAug 18, 2020AspirantYes when RBK852 launched
- plemansAug 18, 2020Guru - Experienced User
The link I gave you shows you can purchase it now.
