Psychopasta
Jul 20, 2022Aspirant
When to Use IoT on Orbi RBRE950
 Hi,     I have an RBRE950 with two satellites, all working fine.     I have my main network running on 2.4 and 5 GHz, and I also have an IoT version running 2.4 only. When should I use this? I'm imag...
- Jul 20, 2022
This IoT network SSID satisfies the desire of customers who demand a "2.4G only" SSID. If the smartphone and IoT device are both connected to this SSID, then all those "issues" with turning off 5G disappear.
Once connected, most IoT devices can be controlled through their "cloud" connection (i.e. from anywhere in the world) and thus it doesn't matter if the smartphone is put back on the primary SSID
Psychopasta
Thank you both!
As I try to keep all my SmartHome stuff on the local network and as little as possible on the cloud, and I'm using modeern equipment, I presume I can turn this off without any problem? -- Mark
TC_in_Montana
Jul 21, 2022Virtuoso
You can absolutely turn off the IoT SSID if you have no need for it without any issues.
