ElDje
Jan 07, 2024Aspirant
When trying to "apply" changes, get a "400 Bad Request"
Hi,
I have the same issue...
Firmware up to date (V7.2.6.21_5.0.20)
When selecting, then deselecting the "Support Automatic Pri...
Jan 07, 2024Guru - Experienced User
APIPA was a unknown feature that came in on v.11 back then. We asked NG was that was about but i don't honestly remember the feedback as as to why they put it in, it's been too long. This feature should not be in current v7 FW as NG removed it.
The user should factory reset the RBR and setup from scratch. Be sure to clear out all browser caches as well before starting the setup routine using a web browser and PC.
The user should be able to use any of the 3 IP class referenced as they are mentioned for home IP configurations.
schumaku
Jan 08, 2024Guru - Experienced User
APIPA == Zero-configuration networking
Microsoft refers to this address autoconfiguration method as Automatic Private IP Addressing (APIPA).
Not sure what this would mean for the Orbi Router NAT implementation - in the eyes of the limited memory space 8-)
