cdysthe
Nov 19, 2022Virtuoso
When will Netgear fix it's IPv6 problem?
I'm not here for help. I have tried everything suggested in several threads to keep IPv6 up and working on my RBR850 with my Xfinity connection. The modem is a Netgear CM2000. Included in what I ha...
Nov 19, 2022Guru - Experienced User
I'd agree, it is broken right now.
My SXK30 it was perfect on. The orbi 9 series I have, it can't keep a solid connection.
A bit of a disappointment.
cdysthe
Just to clarify. Everything else on my 850 system works just great. It's only that I can't get IPv6 to work. Well, with several reboots and settings toggles I get IPv6 for a few hours! 🙂
- plemansNov 21, 2022Guru - Experienced User
Mine's the same. It'll connect and work for a few hours and then it craps out. A bit sad.
