cdysthe
Nov 19, 2022Virtuoso
When will Netgear fix it's IPv6 problem?
I'm not here for help. I have tried everything suggested in several threads to keep IPv6 up and working on my RBR850 with my Xfinity connection. The modem is a Netgear CM2000. Included in what I ha...
Dec 01, 2022Guru - Experienced User
New FW is available:
Included in what I have tried is two other mesh router systems from Asus and TP-Link and IPv6 support is rock solid on both and do not give me "not available" messages when the IP is renewed by the ISP. Please do not suggest I try anything except fixed firmware for my otherwise great RBR850 system.
cdysthe
Dec 02, 2022Virtuoso
Thanks The download link for the router FW 4.6.14.3 doesn't work. The one for the satellite does.
- FURRYe38Dec 02, 2022Guru - Experienced User
Try this link again...it just worked for me.
- cdystheDec 05, 2022Virtuoso
Got the firmware updated. Same IPv6 problem: IPv6 becomes "Not available" after a few hours, sometimes a couple of days and in rare occasions up to a week. Again, I think the problem is DHCPv6 not working correctly on Netgear routers so when the ISP updates the router fails getting the new IP.
- FURRYe38Dec 05, 2022Guru - Experienced User
Ok, thanks for the feedback.
Will pass this on to NG. Will keep on them about this. All we can do.
