ezpzDUDE
Dec 14, 2021Guide
WHEN will NetGear Fix This?
I have a question that I hope can be posed to the NetGear engineers please. I am amazed by how many customers are experiencing the drops with the Orbi Mesh Gear in spite of repeated firmware upda...
CrimpOn
Dec 14, 2021Guru - Experienced User
ezpzDUDE wrote:
However, I have learned that Orbi's mesh ONLY uses WiFi to sync between the Router and Satellite (even though I am hardwired throughout the house).
This is incorrect. Orbi satellites can be connected to the router with ethernet cable.
I have seen posts recently about Beta firmware for the 750 series. If this Orbi was purchased within the last 90 days, maybe you could contact Netgear and ask for that firmware. Or, search the forum for "beta"
ezpzDUDE
Dec 14, 2021Guide
Thank you for the comment. I am aware of the backhaul support that you described. However, NetGear Premium support was not able to confirm the following: That upon first instantiation (a new installation) and subsequent verification, it is the wireless backhaul that is used and not wired. And that the reason for the these dropouts occur b/c of the interference or distance issues that occur. That is what I am waiting to hear from anyone that can speak to that.
- FURRYe38Dec 14, 2021Guru - Experienced User
From what I understand, RBS first wirelessly sync and use the wireless back haul all the time. I don't know how often the RBS touch base with the RBR or even if they do that once they are synced. I presume there maybe some form of periodic status checking that maybe happening as this provides the RBR with status information that gets reported on the RBRs UI.
When the RBS are ethernet connected, then wired backhaul is used. However, the wireless backhaul radios are still running and these are not user configurable. These remain running due to one reason is that if the ethernet connection stops or goes down, the RBS have something to fall back on to get re-connected to the RBR.
