MarkhAUS
May 27, 2022Guide
When will you fix the issue with orbi rbr750 wifi dropping issues!!!
Seeing lots of posts about internet dropping with the most recent firmware I have a fttp (fibre to the premise) setup where the termination point is the “modem”. All you need to do is add a rout...
May 29, 2022Guru - Experienced User
"What is the size of your home? Sq Ft? 490" Is this in Feet or Meters?
So if you turn OFF both RBS, does the RBR have problems still?
Try Channels 1 and 40.
What channels are the neighbors using?
MarkhAUS
May 29, 2022Guide
worked it out better overnight....its someware between 430-450 square mtrs (4800 sq feet roughly). if i turn off the satelites i get next to no coverage in my office upstairs
no idea about neibours channels as the are secured and i couldn't guess who is who. ive changed it to 1 and 40 as suggested.
- MarkhAUSMay 30, 2022Guide
this is the only messages/errors in the logs
[DHCP IP: (192.168.1.7)] to MAC address FA:0E:5E:8E:DA:7F, Monday, May 30,2022 09:38:59[DHCP IP: (192.168.1.14)] to MAC address AE:97:95:7C:5B:B4, Monday, May 30,2022 09:36:11[DHCP IP: (192.168.1.17)] to MAC address FA:AB:45:1A:31:79, Monday, May 30,2022 09:36:10[DHCP IP: (192.168.1.11)] to MAC address 30:C9:AB:27:AC:14, Monday, May 30,2022 09:34:38[DHCP IP: (192.168.1.7)] to MAC address FA:0E:5E:8E:DA:7F, Monday, May 30,2022 09:34:19[DHCP IP: (192.168.1.10)] to MAC address 0A:77:5B:3D:58:73, Monday, May 30,2022 09:32:45[DHCP IP: (192.168.1.14)] to MAC address AE:97:95:7C:5B:B4, Monday, May 30,2022 09:32:02[DHCP IP: (192.168.1.7)] to MAC address FA:0E:5E:8E:DA:7F, Monday, May 30,2022 09:31:58[DHCP IP: (192.168.1.10)] to MAC address 0A:77:5B:3D:58:73, Monday, May 30,2022 09:31:49[DHCP IP: (192.168.1.14)] to MAC address AE:97:95:7C:5B:B4, Monday, May 30,2022 09:31:47[DHCP IP: (192.168.1.10)] to MAC address 0A:77:5B:3D:58:73, Monday, May 30,2022 09:31:42[DHCP IP: (192.168.1.14)] to MAC address AE:97:95:7C:5B:B4, Monday, May 30,2022 09:31:40[DHCP IP: (192.168.1.10)] to MAC address 0A:77:5B:3D:58:73, Monday, May 30,2022 09:31:39[DHCP IP: (192.168.1.14)] to MAC address AE:97:95:7C:5B:B4, Monday, May 30,2022 09:31:37[DHCP IP: (192.168.1.10)] to MAC address 0A:77:5B:3D:58:73, Monday, May 30,2022 09:31:37[DHCP IP: (192.168.1.14)] to MAC address AE:97:95:7C:5B:B4, Monday, May 30,2022 09:31:36[DHCP IP: (192.168.1.9)] to MAC address D8:EB:46:75:A0:2E, Monday, May 30,2022 09:29:51[DHCP IP: (192.168.1.14)] to MAC address AE:97:95:7C:5B:B4, Monday, May 30,2022 09:29:34[DHCP IP: (192.168.1.4)] to MAC address 82:EA:E7:EA:4E:C8, Monday, May 30,2022 09:29:31[DHCP IP: (192.168.1.12)] to MAC address 88:63:DF:90:94:FD, Monday, May 30,2022 09:29:30[DHCP IP: (192.168.1.2)] to MAC address 10:0C:6B:4C:AE:FF, Monday, May 30,2022 09:29:29[DHCP IP: (192.168.1.14)] to MAC address AE:97:95:7C:5B:B4, Monday, May 30,2022 09:29:29[DHCP IP: (192.168.1.2)] to MAC address 10:0C:6B:4C:AE:FF, Monday, May 30,2022 09:29:10[DHCP IP: (192.168.1.13)] to MAC address C8:9E:43:51:CF:68, Monday, May 30,2022 09:29:09[DHCP IP: (192.168.1.2)] to MAC address 10:0C:6B:4C:AE:FF, Monday, May 30,2022 09:29:06[DHCP IP: (192.168.1.13)] to MAC address C8:9E:43:51:CF:68, Monday, May 30,2022 09:29:04[DHCP IP: (192.168.1.2)] to MAC address 10:0C:6B:4C:AE:FF, Monday, May 30,2022 09:29:04 - FURRYe38May 30, 2022Guru - Experienced User
Ok. Power ON just 1 RBS. Not the 2nd one. Make sure it's out at 30 feet for maybe 40 feet away from the RBR.
For that size of home, you really only need the RBR and 1 RBS placed out well.
There is a thing of havng too much wifi:
- MarkhAUSJun 01, 2022Guide
I’ve moved the satellites to opposite ends of the house with the router about mid way and the issue is better.
- FURRYe38Jun 01, 2022Guru - Experienced User
