sh0
May 09, 2024Aspirant
Where are my wired devices?! RBS850
Hello, I recently purchased and setup an RBS850 system. One satellite. I'm having some strange difficulties with ethernet-wired devices to the satellite. They are getting DHCP addresses, and are r...
- May 09, 2024
Ya, may not be available thru that method so you can manually load it. RBS first, RBR lastly.
May 09, 2024Guru - Experienced User
Do the devices appear when connected to the RBR directly and show on the RBRs web page?
What ethernet connected devices are connected to the RBS?
Your behind on FW:
sh0
Thanks! Of course the admin UI shows that they are on the latest. I'll start there.
There are no ethernet devices currently connected to the RBR, they are all connected to the RBS. There are three: Synology NAS, Hue Hub, and a Mac Mini.
- FURRYe38May 09, 2024Guru - Experienced User
- sh0May 10, 2024Aspirant
Thanks. Updating the firmware manually did indeed take care of the problem.
- FURRYe38May 10, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
