Web-raider
Jun 27, 2025Tutor
Where is the new v.7 firmware for RBS350
I have an RBR750 with 2 RBS350, I see the lastest firmware for the RBR is 7.2.7.15. It took me some time but the last time I upgraded my router to 7.2.6.31, I was able to find the RBS350 firmware of...
- Jun 27, 2025
Let us know your results after getting the RBS updated. If problems continue we can troubleshoot more then.
Might consider a full on factory reset and setup from scratch after FW is updated.
Web-raider wrote:
This should work just fine thanks for that.
My RBS350 are currently running 7.2.6.31 and prior to your post I updated my RBS750 & RBR750 to 7.2.7.15.
I really hope this new upgrade fixes the loss of connectivity to my internet, It makes working from home unbearable when your internet keeps dropping. I have frontier fiber which is a direct 1 gig ethernet connection from the ONT straight into my orbi and then I have a 500mb backup internet connection with Spectrum which has never gone done and it has a really old netgear Docsis 3.0 router that has never gone down, go figure.
Jun 27, 2025Guru - Experienced User
Your system is appart of the 650 series which only supports using same version of FW on the RBS AND on the RBR. So if the RBS350s or 650 series don't how v7.2.7.15 at all, then you'll need to downgrade the RBR back to v.31 from here:
New - RBK653 Firmware Version 7.2.6.31 Released | NETGEAR Communities
However I see v.16 FW available for the RBS here: https://www.netgear.com/support/product/rbk652s/#download
So maybe just update the RBS if they are connected currently.
