Web-raider
Jun 27, 2025Tutor
Where is the new v.7 firmware for RBS350
I have an RBR750 with 2 RBS350, I see the lastest firmware for the RBR is 7.2.7.15. It took me some time but the last time I upgraded my router to 7.2.6.31, I was able to find the RBS350 firmware of...
- Jun 27, 2025
Let us know your results after getting the RBS updated. If problems continue we can troubleshoot more then.
Might consider a full on factory reset and setup from scratch after FW is updated.
Web-raider wrote:
This should work just fine thanks for that.
My RBS350 are currently running 7.2.6.31 and prior to your post I updated my RBS750 & RBR750 to 7.2.7.15.
I really hope this new upgrade fixes the loss of connectivity to my internet, It makes working from home unbearable when your internet keeps dropping. I have frontier fiber which is a direct 1 gig ethernet connection from the ONT straight into my orbi and then I have a 500mb backup internet connection with Spectrum which has never gone done and it has a really old netgear Docsis 3.0 router that has never gone down, go figure.
Web-raider
Jun 27, 2025Tutor
- KevinLiTJun 27, 2025NETGEAR Moderator
Hello Web-raider,
Welcome to the NETGEAR Community!
I understand that you would like to upgrade your RBK653 to the latest FW version. To date, the latest Firmware for your RBK653 is FW v7.2.7.15 for your RBR750 and FW v7.2.7.16 for your RBS350.
Please navigate below for the download link to the latest FW that is compatible with your RBK653:
https://kb.netgear.com/000066702/RBK653-Firmware-Version-7-2-7-16
As mentioned by FURRYe38, Be sure to update the satellites (RBS350) first!
Best,
Kevin
Community Team
- FURRYe38Jun 27, 2025Guru - Experienced User
I really hope this new upgrade fixes the loss of connectivity to my internet, It makes working from home unbearable when your internet keeps dropping. I have frontier fiber which is a direct 1 gig ethernet connection from the ONT straight into my orbi and then I have a 500mb backup internet connection with Spectrum which has never gone done and it has a really old netgear Docsis 3.0 router that has never gone down, go figure.- Web-raiderJul 03, 2025Tutor
Update on the RBS350 firmware version 7.2.6.31 and the RBR750 firmware version 7.2.7.15
They have resolved my loss of internet connection to my fiber provider, its been a week straight since I installed the new firmware and I have not had one instance of loss connectivity.
I have even noticed the internet recover time is much faster. I live in FL so due to the severe storms twice my entire community loss power and once the power company restored the power my router took no time connecting and restoring Wi Fi.
As always thanks to the community to help us enjoy our Orbi systems even more.
- FURRYe38Jul 03, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
