Web-raider
Jun 27, 2025Tutor
Where is the new v.7 firmware for RBS350
I have an RBR750 with 2 RBS350, I see the lastest firmware for the RBR is 7.2.7.15. It took me some time but the last time I upgraded my router to 7.2.6.31, I was able to find the RBS350 firmware of...
- Jun 27, 2025
Let us know your results after getting the RBS updated. If problems continue we can troubleshoot more then.
Might consider a full on factory reset and setup from scratch after FW is updated.
Web-raider wrote:
This should work just fine thanks for that.
My RBS350 are currently running 7.2.6.31 and prior to your post I updated my RBS750 & RBR750 to 7.2.7.15.
I really hope this new upgrade fixes the loss of connectivity to my internet, It makes working from home unbearable when your internet keeps dropping. I have frontier fiber which is a direct 1 gig ethernet connection from the ONT straight into my orbi and then I have a 500mb backup internet connection with Spectrum which has never gone done and it has a really old netgear Docsis 3.0 router that has never gone down, go figure.
Web-raider
Jun 27, 2025Tutor
KevinLiT
Jun 27, 2025NETGEAR Moderator
Hello Web-raider,
Welcome to the NETGEAR Community!
I understand that you would like to upgrade your RBK653 to the latest FW version. To date, the latest Firmware for your RBK653 is FW v7.2.7.15 for your RBR750 and FW v7.2.7.16 for your RBS350.
Please navigate below for the download link to the latest FW that is compatible with your RBK653:
https://kb.netgear.com/000066702/RBK653-Firmware-Version-7-2-7-16
As mentioned by FURRYe38, Be sure to update the satellites (RBS350) first!
Best,
Kevin
Community Team
