Web-raider
Jun 27, 2025Tutor
Where is the new v.7 firmware for RBS350
I have an RBR750 with 2 RBS350, I see the lastest firmware for the RBR is 7.2.7.15. It took me some time but the last time I upgraded my router to 7.2.6.31, I was able to find the RBS350 firmware of...
- Jun 27, 2025
Let us know your results after getting the RBS updated. If problems continue we can troubleshoot more then.
Might consider a full on factory reset and setup from scratch after FW is updated.
Web-raider wrote:
This should work just fine thanks for that.
My RBS350 are currently running 7.2.6.31 and prior to your post I updated my RBS750 & RBR750 to 7.2.7.15.
I really hope this new upgrade fixes the loss of connectivity to my internet, It makes working from home unbearable when your internet keeps dropping. I have frontier fiber which is a direct 1 gig ethernet connection from the ONT straight into my orbi and then I have a 500mb backup internet connection with Spectrum which has never gone done and it has a really old netgear Docsis 3.0 router that has never gone down, go figure.
Jun 27, 2025Guru - Experienced User
Web-raider wrote:This should work just fine thanks for that.
Web-raider
Jul 03, 2025Tutor
Update on the RBS350 firmware version 7.2.6.31 and the RBR750 firmware version 7.2.7.15
They have resolved my loss of internet connection to my fiber provider, its been a week straight since I installed the new firmware and I have not had one instance of loss connectivity.
I have even noticed the internet recover time is much faster. I live in FL so due to the severe storms twice my entire community loss power and once the power company restored the power my router took no time connecting and restoring Wi Fi.
As always thanks to the community to help us enjoy our Orbi systems even more.
- FURRYe38Jul 03, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
