akhilstyle
Apr 04, 2021Tutor
Which additional satellite for RBK753
Hi, I have an RBK753 - 1 router and 2 satellites via Ethernet backhaul. I would like an additional satellite. Do I have to get an RBS750 or can I get something else that will integrate with my mesh...
- Apr 04, 2021
RBS 7 or 8 series work.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Apr 04, 2021Guru - Experienced User
- akhilstyleApr 05, 2021TutorHi,
Thanks for your reply. 4000 square feet - however the internal walls are all brick so the signal can drop quite quickly.
The router is in the middle of the house. The 2 satellites are in 2 of the corners. Distance wise this is around 40ft. But they are both connected via Ethernet to the router.- FURRYe38Apr 05, 2021Guru - Experienced User
OK, ya brick will be a factor for sure.
