donawalt
Aug 16, 2020Hero - Experienced User
Which MAC address is my router?
In the web interface at orbilogin, if I go to Basic/Internet Setup, it shows the router MAC address ending in :8A. Yet, if I go to Advanced/Router Info, it shows a MAC address for the router identica...
- Aug 16, 2020
donawalt wrote:In the web interface at orbilogin, if I go to Basic/Internet Setup, it shows the router MAC address ending in :8A. Yet, if I go to Advanced/Router Info, it shows a MAC address for the router identical except the last digits are :89. Does the router have two MAC addresses or something? I have not seen this before.
You are seeing differences in the MAC address for the WAN (to your ISPP) vs. the MAC address for your LAN (within your home network). Here's another explanation: https://superuser.com/questions/1506247/why-is-my-router-mac-address-off-by-1-digit
Mikey94025
Aug 16, 2020Hero
donawalt
Of course, thanks! Is the MAC address :8A under Basic/Internet/Router Address the WAN MAC, and Advanced/Router Information :89 the LAN MAC (since it is right above the 192.x.x.x internal IP address)?
- Mikey94025Aug 16, 2020Hero
donawalt wrote:Of course, thanks! Is the MAC address :8A under Basic/Internet/Router Address the WAN MAC, and Advanced/Router Information :89 the LAN MAC (since it is right above the 192.x.x.x internal IP address)?
Yes. You can also see the LAN MAC displayed for your Router's 192.x.x.x internal IP address with "arp -a" (this command also works in Windows cmd.exe). I use Advanced in orbilogin.cmd, where ROUTER INFORMATION shows all the LAN info and the LAN MAC while INTERNET PORT shows the WAN info and WAN MAC.
