Don_NC
Aug 20, 2020Aspirant
Which mesh system for inside and then outside?
I just moved into an old house with plaster walls and out buildings, one being a pool house. The current WiFi does not reach the back of the house from the router in the front room. Want to install m...
- Sep 05, 2020
Good to hear. Glad it's working well. Please mark your thread and solved so others will know.
Enjoy. đ
Aug 20, 2020Guru - Experienced User
The distance between the 2nd and 3rd RBS maybe a bit too far for Orbi systems. it might work. Generally 60-70 feet is about the limits for Orbi systems. Its something to try and see though. Could work however distance may see poor connections.
The only outdoor RBS is the RBS50Y that only works in Extender mode with the Orbi AX. If you did the Orbi AC then the RBS50Y would work in MESH mode.
Sonething else to consider if you want to try Orbi AX, run buried CAT6A LAN cableing from the house out to #2 and #3 positions then you can run RBS wired, though #3 will need to be in side a structure or some forum of houseing. IF you can't run a cable to #3 position, then you can connect the #3 RBS to #2 that could be wired from the house.
Don_NC
Aug 25, 2020Aspirant
FURRYe38 Thanks for the response. The distances are my concern which you confirmed. I may try to give the cableing a go to #2 & #3 since one will support part of the security system and the other proper TV reception stream for whatever football season we may have ... both important for different reasons.
- FURRYe38Aug 25, 2020Guru - Experienced User
Lets us know how it goes.
- Don_NCSep 05, 2020Aspirant
FURRYe38 I set up the system with just two satellites in daisy chain formation. Did not add another in pool house and did not connect with cables just to see how it would perform. Signal is very strong at garage (60' from RBS1) and we actually streamed a show on the TV last night at the pool house (75' from RBS2) and it worked like a champ. I was blown away and no trenching! Thanks for your help.
- FURRYe38Sep 05, 2020Guru - Experienced User
Enjoy. đ
- Chuck_MAug 26, 2020Mentor
Don_NC wrote:FURRYe38Thanks for the response. The distances are my concern which you confirmed. I may try to give the cableing a go to #2 & #3 since one will support part of the security system and the other proper TV reception stream for whatever football season we may have ... both important for different reasons.
This is precisly how my home is configured... From RBR850, hard wired to an RBS50 (a long distance!) to cover the pool house area. I also have an RBS850 and other hardwired RBS50 providing full coverage over property and it works like a champ.
Once it becomes easier to buy RBS850s, I will replace the RBS50s -- purely an unplug, replug operation.
