Don_NC
Aug 20, 2020Aspirant
Which mesh system for inside and then outside?
I just moved into an old house with plaster walls and out buildings, one being a pool house. The current WiFi does not reach the back of the house from the router in the front room. Want to install m...
- Sep 05, 2020
Good to hear. Glad it's working well. Please mark your thread and solved so others will know.
Enjoy. đ
Don_NC
Aug 25, 2020Aspirant
FURRYe38 Thanks for the response. The distances are my concern which you confirmed. I may try to give the cableing a go to #2 & #3 since one will support part of the security system and the other proper TV reception stream for whatever football season we may have ... both important for different reasons.
Aug 25, 2020Guru - Experienced User
Lets us know how it goes.
- Don_NCSep 05, 2020Aspirant
FURRYe38 I set up the system with just two satellites in daisy chain formation. Did not add another in pool house and did not connect with cables just to see how it would perform. Signal is very strong at garage (60' from RBS1) and we actually streamed a show on the TV last night at the pool house (75' from RBS2) and it worked like a champ. I was blown away and no trenching! Thanks for your help.
- FURRYe38Sep 05, 2020Guru - Experienced User
Enjoy. đ
