Don_NC's avatar
Don_NC
Which mesh system for inside and then outside?
I just moved into an old house with plaster walls and out buildings, one being a pool house. The current WiFi does not reach the back of the house from the router in the front room. Want to install m...
  • FURRYe38's avatar
    Good to hear. Glad it's working well. Please mark your thread and solved so others will know.
    Enjoy. 😉
