ant
Apr 05, 2022Prodigy
Which models can handle to handle a 4.5K acre area for both indoor & outdoor?
Will a Netgear Orbi be handle to handle a 4.5K acre area for both indoor (2 floors house) and outdoor (e.g., large backyard that goes down the hill deep from the house)? Thank you for reading a...
Apr 06, 2022Guru - Experienced User
Are you planning on adding a bunch of access points around the area?
If not, then nothing.
And to clarify, you have 4500 acre area? (4.5K area)
- antApr 06, 2022Prodigy
4500 acres. So, Orbi can't do it with its multiple satellites?
- z8Apr 06, 2022Guide
4500 acres is a 3 mile x 3 mile square.
I'm not sure a residential mesh network is really what you need to be looking at for that kind of area.
- plemansApr 06, 2022Guru - Experienced User
4500 acres= 196 million square feet.
Even a pro system with just a router/satellite pair covers 6000 sqft.
Each add on satellite covers another 3000sqft.
Not going to happen. Thats what cellular coverage is for.
