ant
Apr 05, 2022Prodigy
Which models can handle to handle a 4.5K acre area for both indoor & outdoor?
Will a Netgear Orbi be handle to handle a 4.5K acre area for both indoor (2 floors house) and outdoor (e.g., large backyard that goes down the hill deep from the house)? Thank you for reading a...
Apr 06, 2022Guru - Experienced User
Are you planning on adding a bunch of access points around the area?
If not, then nothing.
And to clarify, you have 4500 acre area? (4.5K area)
ant
Apr 06, 2022Prodigy
4500 acres. So, Orbi can't do it with its multiple satellites?
- z8Apr 06, 2022Guide
4500 acres is a 3 mile x 3 mile square.
I'm not sure a residential mesh network is really what you need to be looking at for that kind of area.
- plemansApr 06, 2022Guru - Experienced User
4500 acres= 196 million square feet.
Even a pro system with just a router/satellite pair covers 6000 sqft.
Each add on satellite covers another 3000sqft.
Not going to happen. Thats what cellular coverage is for.
