ant
Apr 05, 2022Prodigy
Which models can handle to handle a 4.5K acre area for both indoor & outdoor?
Will a Netgear Orbi be handle to handle a 4.5K acre area for both indoor (2 floors house) and outdoor (e.g., large backyard that goes down the hill deep from the house)? Thank you for reading a...
ant
Apr 06, 2022Prodigy
Oops. I meant to say 4,500 sq. ft.
- plemansApr 06, 2022Guru - Experienced User
the orbi setup should be able to cover 4500sq ft and you could add satellites as needed for move coverage. the outdoor gets trickier.
- FarmerBob1Apr 06, 2022Luminary
I got a firmware update that borked my Sats and tried the RBR850 Solo and it's covering 5000+sf nicely. I have troublesome devices that are are outside on the grounds and they are the first to jump on.
