Me_chelled
Apr 20, 2023Follower
Which NETGEAR router and mesh wifi system for use with cable
Hi, hoping for recommendations. I have Fios cable internet and IP supplies Router is not meeting my needs. I am looking to replace with a mesh wifi/LAN system. Which NETGEAR product will work for this...
Apr 21, 2023Guru - Experienced User
What current router do you have? (gives us an idea of whats not cutting it currently)
Are you going to be centrally locating it?
What is the internals of your house made from (certain materials block wifi)?
What speeds do you pay for or plan on upgrading to?
Whats your budget? (pointless to recommend a super expensive system if it isn't in the budget)
What do you use it for?
