brdnwi
Jan 30, 2024Follower
Which Orbi System is best for my situation?
Hi, I'm think about setting up a mesh network in my home, but I'm not sure which setup is best for my situation. I want to start by saying everything we use for gaming or HD streaming is hardwire...
Jan 30, 2024Guru - Experienced User
Best to check on what may work best for you by selecting something based on home side. Having too much wifi in the home can over saturate the home and cause problems with any MESH system:
https://www.netgear.com/hub/wifi/mesh/orbi-buyers-guide/
https://community.netgear.com/t5/Orbi/Find-Your-Orbi-With-the-NEW-Orbi-Product-Selector/m-p/1907267/highlight/true#M91216
https://www.netgear.com/orbi/wifi-systems.aspx
https://kb.netgear.com/31097/How-many-devices-can-my-Orbi-system-support
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
