EagleLanded
Oct 13, 2021Star
Why are Netgear not facing their customers
What is going on in this company - is it en deep trouble? Non working FW - forced to your system, and making it useless - Yes Security issues explored, probaly reason why Parent control disconnecte...
Oct 13, 2021Guru - Experienced User
Was your post beneficial and provide details we'd need to help? no
did you post in the proper forum? yes
Can we help you with such minimal details of the problem, your full setup, and what you've tried doing to fix it? No.
Does official netgear hang out on the forums? rarely.
Is this the public support forum where members of the public try to help out? yes
Should you contact support if you're having a hardware failure? Yes (click on mynetgear at the top, register an account and the device. from there you contact support)
