Kielty
Aug 25, 2021Star
Why can't Orbi RBK852 Handle wired backhaul properly?
I have been struggling with this issue for ages now.. My RBK852 system really struggles with handling wired backhaul. I have 2 satellites connected to the RBR850 one wired and the other wireless ...
- Aug 25, 2021
How are the RBS connected to the RBR? Directly to the back of the RBR or is there a LAN switch in between? If so, What is the Mfr and model# of the ethernet switch in the configuration?
That behavior may indicate a bad RBS, bad LAN cable, incorrect connection configuration, or incorrect FW version on the RBS.
Something I've not seen with mine...
