Sean7777
Aug 11, 2022Aspirant
Why does my orbi 750 keep dropping my ISP internet connection?
I have the orby 750 router and two satellites. Lately it seems that in the past two weeks, I am periodically experiencing the Internet dropping from my Orbi network. I do not understand why this is o...
Aug 11, 2022Guru - Experienced User
Sean7777 wrote:
The ISP cable modem is a Sagemcom F@st3896UM.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Yes, the router's light changes to a solid magenta color when this happens.
Home is a two story 2500 square foot home.
For this size of home having two RBS deployed maybe too much wifi:
Try turning down the power output of the RBRs wifi radios from 100% to 25% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Router 750R is right next to our cable modem and is connected via an ethernet cable.
The RBR maybe too close to the modem. Try 6 feet from the modem .
Satellites are at least 30 feet apart. Have not any issues with them connecting to the router as my home is wood construction.
Using both 2.4 and 5.0 ghz channels. Not many neighbors nearby...so I only see one network within range of my computer.
Sean7777
Thank you for the suggestions! I will look into them and see if get any better performance!
