PurSpyk
Apr 25, 2023Aspirant
Why does my router show Firmware version 4.20.0.4_3.100.71
Firmware version 4.20.0.4_3.100.71, and when trying to update to this version it says the firmware already installed is newer (i have an orbi R350)
CrimpOn
Apr 25, 2023Guru - Experienced User
Wow. Thanks for the screen shot. This appears to be a version of the RBR350 created specifically for
i.e.
https://kb.netgear.com/000064678/RBR350-RBS350-1VNNZS-Firmware-Version-4-20-0-4
Is this your Internet Service Provider (ISP) ?
PurSpyk
Apr 26, 2023Aspirant
Hi, no 2degrees in New Zealand
- CrimpOnApr 26, 2023Guru - Experienced User
Seems a strange coincidence that when I enter "RBR350" into the support web page, there are two version of the RBR350 system:
https://www.netgear.com/support/
RBR350 and RBR350-1VNNZS.
Can you check what model number is printed on the bottom of your router?
