muusicman
Jul 30, 2023Aspirant
Why does this happen with my iPad and/or iPhone RBR850 and RBS850
When I move from the room my Orbi router is in to where my Orbi satellite is i get this a lot when I look at the connected devices. Anyone know why and is there an easy fix? It’s annoying! I was go...
Jul 31, 2023Guru - Experienced User
What are you getting alot of?
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
I was going to add a photo but it appears I can’t. Anyway, under connected devices on the Orbi app sometimes it’ll only show a signal of 1 or 2 bars. Sometimes it doesn’t but it does a lot. Why is it doing that?
