ant
Oct 08, 2021Prodigy
Why is Orbi router's 192.168.1.1 not using HTTPS?
My web browsers complain about this. If I force it, then it says "192.168.1.1 uses an invalid security certificate. The certificate is not trusted because it is self-signed. The certificate is not va...
Oct 08, 2021Guru - Experienced User
Have you tried https://192.168.1.1 in a web browser?
ant
Oct 08, 2021Prodigy
Yes, it says: "192.168.1.1 uses an invalid security certificate. The certificate is not trusted because it is self-signed. The certificate is not valid for the name 192.168.1.1. Error code: MOZILLA_PKIX_ERROR_SELF_SIGNED_CERT". :(
- FURRYe38Oct 08, 2021Guru - Experienced User
Yep thats known for NG routers and there certificates. NG uses self assigned certs and not ones validated by certificate authorities. Just have to continue past this.
- antOct 08, 2021Prodigy
FURRYe38 wrote:Yep thats known for NG routers and there certificates. NG uses self assigned certs and not ones validated by certificate authorities. Just have to continue past this.
Thanks. Do their apps have this problem too? I don't use them.
Like Orbi app? No.
