dpg010
Aug 13, 2021Follower
Why wont netgear allow me to downgrade my firmware, where is the "yes" button? (RBR750/RBS750)
First off, why isnt there a "disable automatic firmware update" option? This is a bit ridiculous. Ive spent close to 800-850 on my entire setup including an additional satellite and support contracts...
MH135
Aug 13, 2021Tutor
It does affect our wifi speed! I am constantly disconnected from my meetings because I'm getting between 12-18 mbps speeds on my laptop. This is ridiculous! Did Netgear NOT test this firmware before publishing it? And why isn't there a auto update disablement button for the Orbi? I was very happy with the previous firmware. Never had one issue with it but since the new update, nothing but constant issues.
Also, the "yes" button to proceed with a firmware rollback, how was that missed in QA?
Aug 13, 2021Guru - Experienced User
Try disabling AX mode on the RBR...
Was this speed test result thru the RBRs Speed test app or external speed test app?
Once one v4 you can't revert back to v3. This seems to be intentional.
- MH135Aug 13, 2021TutorI disabled AX, let the Orbi reboot, did a speed test and still the same results. Then I unplugged the Orbi for a few min and plugged it back in. Still the same results.
Speed test through the Orbi app shows 600+mbps but that is not the issue. It is wifi. I did a speed test through 2 laptops and 2 phones with the same horrendous results. Not being able to revert back to V3 from a V4 whether intentional or not, it should be fixed to allow users to go back to whatever firmware version they were happiest with.
I have gone through the forums and tried all the "fixes" but no success because all the rollbacks were in regards to V3 to a V3. I have no found a discussion where someone was successful in rolling back from V4 to V3. You might be correct in stating it is an intentional design to prevent anyone from going from V4 to V3, and again, if it was, it's a terrible decision.- FURRYe38Aug 13, 2021Guru - Experienced User
You'll need to contact NG support and let them know what your seeing.
