Parth_Goyal
Oct 05, 2020Aspirant
WiFi 5 vs WiFi 6 with majority WiFi 5 devices
I'm looking forward to setup my home network. Entire home's on automation, so network will be extensive. I'll be installing Orbi Mesh WiFi. Currently almost all devices are WiFi 5. Over a period of t...
Mstrbig
Oct 06, 2020Master
Parth_Goyal wrote:I'm looking forward to setup my home network. Entire home's on automation, so network will be extensive. I'll be installing Orbi Mesh WiFi. Currently almost all devices are WiFi 5. Over a period of time 25% devices might be WiFi 6 but majority would still be WiFi 5(automation).
1.Which one would provide better efficiency Orbi AC or Orbi AX? (in my case)
2. Is it that if a device is WiFi 5, then WiFi 5 router would provide better efficiency than WiFi 6 or would it be same in both?
*I'm asking because my majority devices would be WiFi 5 but, I want my network to be future ready.
Thanks.
The AX line, without a doubt, has overall better performance. I've noticed a drastic difference, even with WIFI5 devices having faster speeds and better performance. It's like having a 100Mbps internet and devices with 100Mbps network cards. Then you update the cards to 1Gbps and all of a sudden your performance level goes up. Even though your internet speed is 100Mbps, you can see a drastic difference.
Add to that you now have WIFI6 compatibility. My WIFI6 devices are much faster. For instance my laptop had a 350 to 400 Mbps WIFI speed. Now it has over 800Mbps constant speed. I just checked by WIFI6 compatible phone and I am at 780Mbps vs. 340 average before.
- Parth_GoyalOct 06, 2020Aspirant
So, as per my setup where there would around 100 lighting automation circuits, 50 IOT devices like cameras, security & sensors and 50 personal devices such as mobiles, PCs & TVs. Where majority would be WiFi5 as mentioned above. What should I go forward with? Is RBK750 a great choice.
Thanks
- FURRYe38Oct 07, 2020Guru - Experienced User
IF you can find a place that as a good refund policy, get a Orbi AX system and try it out. if you don't like it, then you get return it.
- MstrbigOct 07, 2020Master
Parth_Goyal wrote:So, as per my setup where there would around 100 lighting automation circuits, 50 IOT devices like cameras, security & sensors and 50 personal devices such as mobiles, PCs & TVs. Where majority would be WiFi5 as mentioned above. What should I go forward with? Is RBK750 a great choice.
Thanks
I personally own an RBK753 system (1 router, 2 satellites). So if you need 1 router and 1 satellite the RBK50 is an excellent choice.
If you need more coverage go with the RBK753, a little more power, go with the RBK850 or 853 for more power and coverage.
- Parth_GoyalOct 08, 2020Aspirant
I'll be having around 100 lighting automation circuits, 50 IOT devices such as Cameras, security & alexas and 50 persnal devices such as mobiles, TVs & PCs.
