Parth_Goyal
Oct 05, 2020Aspirant
WiFi 5 vs WiFi 6 with majority WiFi 5 devices
I'm looking forward to setup my home network. Entire home's on automation, so network will be extensive. I'll be installing Orbi Mesh WiFi. Currently almost all devices are WiFi 5. Over a period of t...
Parth_Goyal
Oct 06, 2020Aspirant
So, as per my setup where there would around 100 lighting automation circuits, 50 IOT devices like cameras, security & sensors and 50 personal devices such as mobiles, PCs & TVs. Where majority would be WiFi5 as mentioned above. What should I go forward with? Is RBK750 a great choice.
Thanks
Oct 07, 2020Guru - Experienced User
IF you can find a place that as a good refund policy, get a Orbi AX system and try it out. if you don't like it, then you get return it.
