Magicboy
Mar 26, 2021Tutor
WiFi 6 / RBR850 issues
Hi, I have an RBR 850 wired command center and one satellite upstairs. On my MacBook Pro I constantly get an issue with the WiFi connection dropping - unstable connections during zoom calls, my mail g...
Mar 26, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What OSX version are you using?
