Magicboy
Mar 26, 2021Tutor
WiFi 6 / RBR850 issues
Hi, I have an RBR 850 wired command center and one satellite upstairs. On my MacBook Pro I constantly get an issue with the WiFi connection dropping - unstable connections during zoom calls, my mail g...
Mar 26, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What OSX version are you using?
vajim
Apr 12, 2021Master
still trying to figure this out?
- MagicboyApr 12, 2021TutorHi - yes, thx, I’m great with tech but I’m not a techie and the answers were too technical for me to make head or tails of, as much as I appreciated them. 3500 sq ft. MacBook and IPhone drops intermittently. Sonos sometimes fails to connect, then connects if I refresh the app. Previous set up was a straightforward AT&T router. No issues on that, but didn’t have the range or the speed. Now I have the range, but not the consistency of connection. Thanks for any layman help! Simon.
- FURRYe38Apr 12, 2021Guru - Experienced User
Maybe someone can help you gather this information.
