Elwood_85
Jan 05, 2023Aspirant
WiFi 6 icon is on my Samsung S21 BUT Orbi RBRE960 Attached Devices shows Connection Type as 5G
None of the other devices attached show 6G even though they are newer devices that are WiFi 6 capable. The Orbi only shows 2.4G and 5G but no 6G . Should there be a 6G icon in Attached Devices Conne...
- Jan 05, 2023
You're confusing wi-fi 6 (which is still 5Ghz) and wi-fi 6e (which uses 6Ghz and the separate radio in your RBRE960). From https://www.tomsguide.com/face-off/wi-fi-6-vs-wi-fi-6e-whats-the-difference:
- Wi-Fi 6 can send and receive data over both the 2.4- and 5-gigahertz (GHz) bands (Wi-Fi 5 is 5-GHz only) and can move even more data by running a single ultra-wide 160-megahertz (MHz) channel on its 5-GHz band.
Wi-Fi 6e added more than a gigahertz of fresh electromagnetic spectrum space in the U.S., ranging from 5.925 GHz to 7.125 GHz... This additional block of spectrum, generally referred as the 6-GHz band
The Android screenshot just indicates Wi-Fi 6, not 6e. From https://www.androidauthority.com/wi-fi-6-910014/ : If you see a number 6 alongside the Wi-Fi symbol, it means that your device is connected to a Wi-Fi 6-capable router.
CrimpOn
Jan 05, 2023Guru - Experienced User
The WiFi Alliance did no one any favors by creating such confusing names.
WiFi6 refers to an improvement over WiFi5 for devices using the 5G Frequency WiFi spectrum
WiFi6E refers to to use of the 6GHz Frequency WiFi spectrum
Devices labeled WiFi6 are built to use 5G.
- CrimpOnJan 05, 2023Guru - Experienced User
Is your Samsung S21 the "Ultra"?
https://www.techietech.tech/wifi-6e-compatible-smartphones/#1_Samsung_Galaxy_S21_Ultra
- Elwood_85Jan 05, 2023Aspirant
No. mine is the Galaxy S21 5G (Sprint) and according to Samsung Specs are Wi-Fi Connectivity
802.11 a/b/g/n/ac/ax 2.4G+5GHz, HE80, MIMO, 1024-QAM With 802.11ax being 6E right?Thanks again CrimpOn
- FURRYe38Jan 05, 2023Guru - Experienced User
2.4G+5GHz this doesn't include 6Ghz so the phone does not support 6Ghz. AX is a wifi MODE not a FREQUENCY, a mode that is seen on 2.4Ghz, 5Ghz AND 6Ghz.
Just so I understand better, in Attached Devices -> Connection Type I will only see Wired, 2.4G and 5G icons but no 6G icon even if devices I have are WiFi 6E capable like my Samsung S21 is and my daughter's new iPhone are 6E capable?
Thank you CrimpOn
This article from last October does not list any Apple iPhones:
