PbInspector's avatar
PbInspector
Follower
May 05, 2020
WiFi-6 Mesh System and DSL
Greetings All,
I live in a rural area where DSL is my one and only ISP through CenturyLink.  I currently have a Zyxel Dual Band C2100Z (from CenturyLink).
My speeds are very slow.  Download averages 10 Mb and Upload is almost always less than 1 Mb.  Upload is mostly 0.70 Mb. These are the highest speeds available.
I am considering an Orbi WiFi-6 Mesh System .  It's my hope that I will be able to maintain no less than the aforemetioned speeds.  Yes, I'm desperate. Can I loose speeds with this Orbi WiFi-6 Mesh System?
1.  Would the newer Orbi AX6000 (RBS850) WiFi-6 be too much of demand for my DSL as described?
2.  I'm hoping this mesh system will expand my wifi to a larger area and more devices. Netgear says this model mesh system has higher performance. Will that Higher Performance be helpful to my DSL?
This is my first ever post and as I said, I'm desprate.
Thank You!!!
1 Reply
