brojack420
Apr 20, 2023Follower
Wifi 6 Orbi Worth It?
Hello everyone, I am trying to decide whether the Orbi RBK852 system would be worth it for my use case. At the moment I am using an Orbi Wifi 3 pack AC2200 (I can't remember the name) system with an ...
Apr 20, 2023Guru - Experienced User
It would be an improvement over the Orbi AC system you have.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
