aamaha
Nov 20, 2024Aspirant
WiFi 6 system - adding one additional?
I have a orbi WiFi 6 system that came with one satellite (two total units) that cover most of my home effectively but I’d like to cover the remaining areas and sitting area just outside our back door...
Nov 20, 2024Guru - Experienced User
should be able to.
Just make sure to get a compatible one to your system. You don't actually put your model number.
Here's the orbi compatibility chart.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
