ArunGupta
Dec 25, 2022Apprentice
WiFi 6E speed slow
I have the RBKE 960 main router connected directly to Verizon Gigabit ethernet cable. At the Verizon cable, I am getting 900/900 download/upload speed. However, connected to WiFi 6E, I barely exceed ...
Dec 26, 2022Guru - Experienced User
What speeds do you get with a pc/laptop hardwired into the orbi?
Verizon is great at supplying modem/router combo gateways. they can cause a double nat.
A double nat happens when you cascade more than 1 router. Potentially your son might have it setup in the correct configuration.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
- ArunGuptaDec 26, 2022Apprentice
a) The hardwired speed at Orbi Ethernet port is 900/900 so it is the WiFi which has poor performance
b) Verizon does not have a separate modem. They have given me a Ethernet cable right from their ONT, so there is no question of double NAT.
