ArunGupta
Dec 25, 2022Apprentice
WiFi 6E speed slow
I have the RBKE 960 main router connected directly to Verizon Gigabit ethernet cable. At the Verizon cable, I am getting 900/900 download/upload speed. However, connected to WiFi 6E, I barely exceed ...
Dec 28, 2022Guru - Experienced User
You can always try a simple factory reset and reinstall.
ArunGupta
Dec 28, 2022Apprentice
Actually that is what I did. After I returned the Orbi 960 purchased from Amazon, I got the second one directly from Netgear. Then I removed the HW firewall and connected the router directly to the internet cable. After that, I updated the firmware on satellites and then on main router and did a factory reset of all three devices. Then I reconfigured the Orbi devices and network from scratch. So, I have spent quite a bit of time with this system and it just does not perform.
