AwesomeQA
Aug 01, 2020Apprentice
WiFi 6E when?
When do you think we will see Orbi AX with 6E in the market? Do you think it would support 160Mhz instead of RBR850 supports only 80Mhz for clients with 6Ghz?
Aug 04, 2020Guru - Experienced User
https://www.theverge.com/2020/4/23/21231623/6ghz-wifi-6e-explained-speed-availability-fcc-approval
Look like it so far:
https://en.wikipedia.org/wiki/List_of_WLAN_channels#6_GHz_(802.11ax)
- CoronatorSep 02, 2020AspirantI think the biggest deal near term at least with WiFi 6E will be a 6ghz backhaul. Will take years for enough WiFi 6E clients to filter in, but that will be an immediate improvement for mesh networks.
- FURRYe38Sep 02, 2020Guru - Experienced User
6E will be a whole new product.
- FarmerBob1Jan 21, 2021Luminary
FURRYe38 wrote:https://www.theverge.com/2020/4/23/21231623/6ghz-wifi-6e-explained-speed-availability-fcc-approval
To add to Mr. Furryes' Wiki Post: IEEE_802.11ax
Although, excerpt from the above: "The 802.11ax (WiFi6) standard is expected to be published in February 2021."
- FURRYe38Jan 21, 2021Guru - Experienced User
Will be interesting to see who comes out with the client HW.
- FarmerBob1Jan 22, 2021Luminary
FURRYe38 wrote:Will be interesting to see who comes out with the client HW.
At the bottom of the page I linked to above is quite a list, in the 4 major categories, of "Devices", including Chipsets that are out by what manufacturer that are capable of the newer tech.
