AwesomeQA
Aug 01, 2020Apprentice
WiFi 6E when?
When do you think we will see Orbi AX with 6E in the market? Do you think it would support 160Mhz instead of RBR850 supports only 80Mhz for clients with 6Ghz?
FarmerBob1
Sep 03, 2020Luminary
I read an article not too long ago about a manufacturer asking the FCC to do WiFi7 testing. I wouldn't be surprised if WiFi now doesn't follow computing porcessor evolution. With a Speed/Level Doubling every 18 months. But now that processor dev is in the single digit nm area, it's slowing. But WiFi is all Blue Sky . . .
Sep 03, 2020Guru - Experienced User
And were just getting 2.5Gb on the WAN port now. Still waiting on the LAN side. Though CPU capasity and processing will be needed for that as time goes on. :smileywink:
